Fuel efficient xr100 motor mods
tomcat955
I am trying to build a fuel efficient go kart with a Honda xr 100 motor. How can I mod the motor for fuel efficiency?
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
FIRST OFF, Guys remember this is for a SCHOOL Project.
Lighten and perfectly balance any and all rotating parts.
Also add a rev limiter to stop operator from a heavy left foot.
Mainly you are gonna get the best mileage by Kart design more than engine.
IE:
Reduce Weight, Aluminum or carbon fiber frame. (Bamboo?)
Skinny tires for less drag
Gearing
Less aerodynamic drag
BattleGroundCycles
Briggs 8hp builder
Utah/Socal
what are the test conditions for the mpg readings?
a properly jetted carb is the first place to start. then the muffler should be free flowing but not a huge diameter. the timing should also be set/adjusted properly. I highly recommend a throttle stop that limits the carb from being wide open. I'd do some testing at set the limit so that the kart can do just over the test speed. If the test includes mainly steady speeds, then weight won't be as important as the aerodynamics. If it is a lot of stop and go, then weight is the #1 thing.
some extra fuel efficency can be had by reducing the cam overlap, this requires you to take the cam out and have it reground. you could do this with a high grit "flapper" sanding disc. but if this is already confusing you, then you better just leave the cam alone.
the kart should have fenders that hug the wheels tightly and hang as low as possible. the gearing should be set around the rpm the motor makes it's peak torque.
An XR100 revs pretty high to make it's 8 or so horsepower, so don't over gear it to the point that you have to pin it in top gear to lug along.
I hope this was helpful.
throttle stop: NO .. never!
if you want to stop the engine from revving too far past the peak torque (and best efficiency)
get a digital rev limiter.
The reason is simple: with a throttle stop you adjust the amount of air (and thus fuel, true) but in the real world there could be road inclinations that alter the situation (say you need a tad more air and fuel uphills to reach the exact same rpm) without opening up the throttle you might be unable to get the engine in it's most efficient state.
personally A well observed tach and a the right foot of a tap dancing elf and you should not need either.
aerodynamics are cool.. when it comes to efficiency at speed.. BUT they add weight..
and they're only beneficial past a certain speed (what speed that is depends on the total weight and the exact aerodynamic coefficient achieved...)
Weight is ALWAYS important.. since it adds to the rolling resistance, not only the accelerative resistance.
You need to get the total Power needed down to the minimum for best fuel efficiency at all times.
I've posted that elsewhere but let me quickly copy it here for your convenience,
the math is quite intimidating considering this has to be recalculated basically all the time
But fear not... once you get the core info you'll be fine.
Pm = m * g * sin(alpha) * v + m * g * Cr * cos(alpha) * v + Ca * m * a * v + 0.5 * Da * Cw * A * v³
m [ total mass of the kart incl passengers, kg ]
g [ gravitational force, 9.81 m/s² ]
alpha [ road inclination angle ]
v [ Velocity (relative), m/s ]
Cr [ Coefficient rolling resistance ] *
Ca [ Coefficient accelerative resistance ] *²
a [ acceleration, m/s² ]
Da [ Air density, kg/m³ ]
Cw [ Coefficient wind resistance ]*³
A [ Area facing the wind kart plus passengers, m² ]
*some Coefficients for rolling resistance
Code:
[B]Cr		Wheel -> Surface[/B]
0,015-0,02	Motorcycletyre on asphalt
0,011–0,015	Cartyre on asphalt
0,01–0,02	Cartyre on concrete
0,020		Cartyre on gravel
0,015–0,03	Cartyre on cobblestone
0,03–0,06	Cartyre on potholes
0,050		Cartyre on dirt track
0,04–0,08	Cartyre on compacted sand
0,2–0,4		Cartyre on loose sand
*²
Accelerative resistance is a real pain, basically it's all the inertia in the system.
rotating parts where the top part (or path) is travelling in opposite direction (wheels, flywheel, cam, crankshaft, axles, sprockets, clutch, the upper length of the chain...) work against you with their inertia.
So everything needs to be as light and small and slow turning as possible (not too weak though of course.. failure is not acceptable :D)
A real pain as I said.
*³
No way of guessing... it must be tested I'm afraid,
or a pretested readymade set bought.
air density (Da) at 20° C is 1.2 kg/m³ aboutish in case you want to calculate some numbers.
The Cw for a modern sprint kart is 0.62 (with fairing that is)
You can split down into single parts that add up in the above term.
to determine what goes bigger or smaller under what conditions.
here's a detailed breakdown
The thing is, that motor is a dirt racing engine, it's not made to be efficient at all.. it's made to run at high rpms and provide serious grunt.
It's by far not the best base to work from for this task.
So yeah: weight, weight, weight... that's the easiest thing to change
then wheels (magnesium over aluminium, narrow over wide, smallish over tall)
next internal drag.. bearings all highspeed, the lowest moving part count possible..
going slow is more efficient than going fast (very much so)
Bwdeaton
Dayton, Ohio
I don't really have anything to say about increasing the efficiency, but I do want to say that my XR100r is already really good on gas. Can ride all day and not even burn 2 gallons. Mostly ridden by my brother but it is a good bike.
