spongerich
Working on an off-road kart and I'm at the stage where I want to finalize my plans for adding brakes.
I'm using the front a-arms and spindles from a Honda ATV and I have the brake discs, calipers, and master from that, so front brakes will be a breeze.
The rear is a Peerless 900 Transaxle from a lawnmower. I've welded the spider gears in the diff, but I'm afraid that putting a brake caliper on just one axle is going to put a ton of stress on it, so I'm considering putting one on each axle or just having brakes on the front. I have most of the parts I need and can machine some hubs, so cost isn't a big factor, but I don't want to add a ton of extra weight and complexity if I don't need to.
