Free torque upgrades?
Mr. Spindle
middle tn
My dingo is not going to have near to enough torque. Everyone knows that. A 5:1 gear ratio is not going to get me anywhere, so HOW IN THIS INCREDIBLY BIG WORLD am I going to be able to get at least two FREE torque upgrades????? Help, please! This is the wall between being done!
:surrender::mad2::mad2::mad2:
Bbqjoe
Banned
Location, Location
Son, you said you drink coffee. It's time to wake up and smell it!
Nothing in this world is free. And if it is free, it's probably garbage.
Put that engine back together, put it on your Kart, and go drive the dam thing around and see what you have.
Could try trading parts on here with someone. That's the only way you can get close to free. Otherwise you're going to have to get some money saved up and go 6:1 or 7:1 to the torque you are looking for. Have a cup of coffee and figure this out.
Bbqjoe
Banned
Location, Location
Juice just doesn't have quite the kick he needs. 😎
I have the kick he needs :D
In gerneral, cause you gave no specifics as to mods already done, I got 4 possible free upgrades.
BUT you should change gearing, get smaller tires, or add TC if you want more torque
4 freebies...
Removing stock air box and building a more effiect one out of scrap.
Tuna can adapter? Nylon sock screen filter? A/C filter material?
Removing stock exhaust and building one out of scrap.
Removing the governor.
Advancing the ignition timing using a degree wheel and lapping compound. (May hurt low end, but free modification)
---------- Post added at 02:19 PM ---------- Previous post was at 02:04 PM ----------
5. Port and polish the head.
Bbqjoe
Banned
Location, Location
4 freebies...
Good job Bob!
The kid's already got a half jacked up engine, probably spread all over the chicken coop. Now you're gonna have him tear up some more stuff.
Beautiful mang, just beautiful. :D
KartFab
Dallas, TX
more torque can pretty much only be accomplished by
1) changing gear ratio
2) getting a torque converter (if you dont already have on)
3) getting smaller tires, all else the same
4) modifying engine - contrary to popular belief few 'performance parts' actually give you more torque, but increasing the compression ratio will give more torque all else the same on an engine, which typically involves money.
Staff Murderator
Can't knock him too much--this has become the norm around here.
A typical random, out-of-left-field thread from the fluffy la-la land of Spindle's brain. He's trying to build a pyramid upside down. Wants some unspecified end result without having a foundation first.
Let's have engine-to-wheels first, capicé? Mount the motor!
Branderino
Torque Junkie
Texas
Remove as much weight from the cart (and yourself) as you can. Seriously, weight makes a huge difference. Increase tire pressure, pull apart the motor and remove any buildup, polish the valves/port if your savvy enough. Clean the carb out if its dirty, keep tuning until your certain it can't run any better.
Poboy kartman
Senior Moments Member
White Settlement Texas
Keep in mind...he's 13 years old.
Branderino
Torque Junkie
Texas
I don't think age has an effect on his ability to do any of those things. My brother is 15 years old and he built a kart nearly from scratch (minus the welding)
Most of these are pretty simple things to do, and Youtube is a powerful tool when it comes to things like this.
Poboy kartman
You know what else is easy Brandon ? Filling out a profile.... Let's us know where you are and a little more about you.
You can head down any road you want....but.. Right now, it looks like you are on DIPSTICK HIGHWAY!
