free lawnmower
kendelrk
redneck engineer
westland michigan
well i got her running and shes running good, i have it without a primer bulb right now, so it takes a few pulls, but its great
kendelrk
redneck engineer
westland michigan
the main jet and over it, because in both this main jet and the e tube, the e tube was clean, but in the top of the main jet its a big hole followed by a tiny tiny hole, so i put off a thing of bread tie, pushed it through the little tube next to the e tube and that little jet. and it ran. i have noticed, that it needs a prime to get her started when shes really cold, and i havent put it back on yet, how exactley does the primer work? because it runs through the breather hose from the air filter, but thanks toy story and everyone else for the help
redsox985
PA
that was doing weird stuff. LOL.
too bad my 6hp briggs has a tapered shaft.
Better yet! It doesn't have any immediate kart value so if you butcher it, it's not like an immediately usable engine was trashed. If it does work, get the PTO lathed or get a straight one.
sideways
Unfinished projects king.
Perth, Western Australia
I just cut it out of a piece of steel plate. Probably 2.5mm thick.
I made a few mock ones out of tin first, when I was happy with the design I used it as a template for my final one.
oscaryu1
That dipper's gonna bend so **** easily at high revs... I'm putting money that motor'll blow in a couple days.
karl
North east Ohio
Oil harden it with some used motor oil and a torch, then temper it by heating it up again, but not as hot and let it cool.
Bluethunder3320
you think a 5hp briggs dipper would work?
well mines a taper shaft, pulley is rusted on good, and it has a slight wobble.
EDIT: also it would make the dipstick horisontal and it would definately leak out the worn seal.
