free lawnmower
kendelrk
redneck engineer
westland michigan
i was given a briggs 5 horse lawnmower. that isint running, so i checked spark, its there, put a little gas in the plug hole and there it was running for a few seconds, put some in the carb and it didnt which means its plugged, according to who gave it to me, it hasent ran in 5 years and they were to busy to do anything with it, think itll make a decent motorized bicycle?
No. Big and heavy, and vertical. Look for a smaller engine in a horizontal configuration, preferably a 2-stroke (size and weight).
I think it'll make a good lawnmower.
porsche930dude
Upstate, NY
Nope sell it for an easy 30$ . Gotta get it running first though. Pull the bowl off the carb and spray out the holes best you can and make sure the float isnt leaky. if that dont get it going youll have to pull the carb off so you can get at it better and clean it real good
kendelrk
redneck engineer
westland michigan
i was thinking to get a pulley and keep the crankshaft bolt so when i push the pedals it starts with friction drive, and not really looking for lawnmower, i have a newer 5.5 briggs sitting in the garage for mowing the lawn
kendelrk
redneck engineer
westland michigan
and where would i find the year of the engine on this mower? ive heard of briggs having the year of the engine printed on a code somewhere on thesse engines
kendelrk
redneck engineer
westland michigan
haha it even has an idle to full speed lever on the top perfect.and where would the cide be, and i can do it like a skate board, and is it really going to move itself blue?
Bluethunder3320
Sure itll move. I was thinking of doing it to one of my free mowers for kicks, but i took them apart and im rebuilding both engines. Just need time.
Ones a 5.3 tecumseh bout 25 years old, ones a 6hp briggs about 20 years old, just needs a carb clean i think......
Once i sat on my honda mower while my friend pushed me, it was SCARY at 10 mph give or take.
kendelrk
redneck engineer
westland michigan
i gave it gas in the head, it runs, gas in the carb nothing, cleaned the carb, tried Again, gas in the head fires, gas in the carb dosent,
sexyvicta
i get free/cheap lawnmowers all the time to fix and then sell.
80%-ish of them have this problem(the rest have been faulty spark plug and one had a blown head gasket).
Clean the carb (again)
or try spraying carb cleaner in the intake and see if it will fire
edit: i guess once you're sure that your carb is doing its job you will have to work out why the engine isn't ingesting fuel. Check for airleaks downstream of the carb...if no problems there then check your valves etc are working as they should. After that i have no idea.
Carb's gummed up. In another thread you suggest you need another float needle seat. Generally speaking, and from anything I've ever gathered- when the seat is bad, the needle won't seal, causing flooding/overflows. You're saying here you're getting no fuel. Big difference.
Just spraying carb cleaner around may not do it. Remove the jet, visually inspect. If you can't see thru it, it's clogged. If the hole is really really tiny, it's clogged. If your carb has a high speed needle, remove and clean. Now- before you start randomly ripping needles out- Gently screw it all the way in until it seats (not hard) while counting the number of turns it went in. This way when you reassemble it, you have a starting point for it.
kendelrk
redneck engineer
westland michigan
i can get a small plastic paper clip unfolded threw the bottom holes, but not the top it only goes so far in and you cant see in through the bottoms is that clogged? and it has a high speed screw, and it took 10 to get it out
