Frankenkart
kjsifer
Hey guys, my first post here. I've done my research but I'm a little baffled as to what to do. My son bought this Yerf-Dog kart with a Honda 8 HP engine on it. We knew it needed a new belt, so I bought one for a series 20 Comet clutch. I measured it and bought the correct sized belt.
Being a newbie, I didn't take the old belt off to look closely at the driven pulley. Now that the belt arrived, I realize that my driven pulley is a Series 30, which needs an asymmetric belt. Unfortunately, the drive clutch needs a symmetric belt, so I am not sure if is a series 20 or if it is even a Comet clutch. So, the Comet v-belt for series 20 is not going to work right unless I change the driven pulley to a symmetric style. Our biggest problem with the kart right now is that it won't sit still at idle, obviously because things are all mixed up.
I am thinking about changing out the series 30 driven pulley with a series 20 driven pulley because the existing driven pulley is a little rough, but since I am not sure the drive clutch is even a Comet clutch, I thought I would poll the masses and get your expert opinions. There are no markings on the drive clutch and it doesn't look like any pictures I see out there. It's all very confusing for this newbie!!
KJ
I have absolutely no clue what sort of driver that is! I've never seen one like that. Can we have a pic with the belt off?
Since that driver really does seem to be entirely bizzarre, I'd ditch it...
EDIT- I keep staring at that thing. Is it even a CVT driver? Sure don't look like one! I'd really like some detailed pics from several angles.
I don't think the Yerfs came with 8hp Hondas- I'm inclined to think that somebody swapped it on there. That really looks like an adjustable sheave pulley. (Adjust to fit A or B section belts or whatever, tighten set screw. Entirely unrelated to CVT's)
kjsifer
Yes,
You are right that somebody put the Honda engine on there. It is not original. So, the more I think about it, the more I think you are probably right, change out the driver. I was not sure the driver pulley was part of a CVT set, so it is probably best to change it since I know that my driven is a series 30.
I wasn't able to take more pictures because I got home late tonight. Will try to snap some this weekend.
kjsifer
Here are more pictures that I was able to take of the driver pulley/clutch. I'm not exactly sure what it is. So, after looking it over would you recommend I just replace it with a Series 30 driver to match the "30" driven?
Thanks,
KJ
kjsifer
Thanks a bunch guys. I REALLY appreciate it. I will get this kart figured out yet!
KJ
