Frame and live axle question
jdsc
I am a new kart builder and am actually building a mini tram that will pull a couple of rolling cars behind it.
For the engine cart I plan to build the frame rails from 2x2 1/8" square tube and I am wondering if any one could provide some advice on whether I can penetrate the frame for a 1" live axel and whether i need mountable bearings on each side of the tube steel.
Thanks!
Badot
Cutting/drilling into the frame is typically a no-no as it lowers the structural integrity of it a fair amount. Obviously beefing it up before doing this would be acceptable, but typically it would take less material and work to weld a mount point to the frame.
Bearings are something you'll definitely want (or at the very least bronze or brass bushings) on all wheels or axles... Steel on steel rubbing isn't good, and eventually you'd have to replace either the axle or a chunk of the frame. Not to mention you also have the potential of it rust welding.
