fox hornet 6hp Subaru engine
jen hall
Lake county FL
:lolgoku:Hey wondering if anyone can help,as I'm very new to this. I bought my boys this cart for Christmas the original owner kept the cart in great shape! It had set up for a bit,cranks first pull great power and speed after a few rides however my son made a sharp turn through softer dirt the wheels locked up engine powered down. After i pushed it a bit the wheels"clicked" unlocked and it fired right up continued to drive fine several more times until again high speed turn same thing wheels locked while pulling starter cord noticed wheels trying to turn and resistance, again after pushing 5 feet or so wheels unlocked fired right up and ran again any ideas?please help? Dont want to continue to use and cause further damage!
colestreasures
Kentucky
Definitely need pics, need to see what you have going on to help, can throw out a few things but rather have pics.
Cole
Poboy kartman
Senior Moments Member
White Settlement Texas
Well....I'd say your TC needs some TLC.....thing is.....the oil puddle....makes me think perhaps the bushing/bearing on the crank cover and seal may be bad....
But being set up like it is....another thing to check is your axle bearings....block up the frame and spin the wheels and axle....it should spin very easily..then ...push and turn....and pull and turn....you shouldn't be able to move it side to side...and you may find a shot axle bearing....(or two)....
jen hall
Lake county FL
Poboy kartman
No oil leak found that dipstick was not tight edited post sorry you didnt see that! I've since moved it back absolutely no oil leaks!
jen hall
Lake county FL
May be just a lack of knowledge but thought it was significant that pull cord moves whheels and cant be pulled all the way until it's "unlocked" then it runs like a sewing machine, no waer on the belt whatsoever! Cranks first pull rides great! Just those two turns that feels like something is grabbing in the rear axle!
Poboy kartman
Cool...glad to hear it...so...probably the TC locking up....(IDK)????
Check those axle bearings though....thing is....why would a locked axle cause the motor not to spin???? Unless the TC is locked up as well???
Hmmmm.....I'll have to think about this one...but I'd almost bet you have 2 problems.....:popcorn:
Bosch
Lincoln, NE
Can you replicate the problem? In other words, can you intentionally induce the stall by repeating the maneuver that you say caused it before?
The reason I ask is because it will help to know if the stall and the turn are truly related to each other, or merely a coincidence.
jen hall
Lake county FL
Thats how I did it yesterday with a sharp turn without slowing(left), slinging back end around, but at the same time cam spin donuts to left and it doesnt happen! Haven't tried again cuz I was afraid of screwing it up even more! When locked though it makes rubbing noise then seems to just release
Bosch
Lincoln, NE
Just to rule out obvious things... Have you checked that the brake caliper isn't loose or something like that?
What you're describing implies that something is shifting out of alignment during a left turn.
jen hall
Lake county FL
No the disc brake seems to be fine I dont see any problems there, as I watch when pushed it tightens up and is clear when not pressed! It almost seems like something in the axle catches at times cuz as I've said donuts are not an issue just those 2 times when making a sudden turn! I will check about play in the back axle
jen hall
Lake county FL
Poboy kartman I think you are on to something, after getting it up on blocks and trying to move axle the left side seems good, no play, the right side however moves back and forth About 1/4-1/2 inch which also causes the belt and chain to move ? Maybe the axle bearing on the right side shot?? If so how much would that fix cost approximately? ?
That depends on how handy you are; if you have the correct tools & can replace them yourself, it'll cost you the price of the bearings ($5-$10 each; there's no point replacing just one, replace both...)
I'm also thinking there is more than one problem; if the low oil sensor is still connected, that may be what's causing the stall &, because it's stalling under power (TC engaged) that is causing the lock-up...
Check the low oil sensor (yellow wire on the front side of the engine); if connected, disconnect it, try the manouvre again & see what happens...
jen hall
Lake county FL
Fabroman and any one else who responded to my questions today it was a big help! I ended up taking the back tires and replacing the bearings, the right was awful the left wasn't too bad but will be putting new ones on it tomorro! Hopefully this will fix the problem! No oil leak at all!
Thanks once again for everything!
lolllh&
Poboy kartman
You're welcome....and thank you! !!! It's what we're here for.....and without folks with problems.....all we have to do is pick on each other.....
And we love happy endings!!!!!
Keep us posted on the results.....and please fill out your profile....so we know where you're from......
And in case you haven't noticed.....we have a lot of fun here joking around too....
Bosch
Lincoln, NE
Even if the problem persists, replacing bad bearings is always good, so don't be discouraged if it still acts up.
colestreasures
Kentucky
I do agree with bad bearings, but if it still acts up make sure the chain is not binding up. Could be to loose of just worn out. JMO
Cole
