for the love of God?! 8ga female spade terminals???
Again, why?
I wouldn't want to run 50 amps through a surface contact. Just asking for problems IMO.
Electric 101. Weak or bad connections make heat and energy loss. Also another spot for electrolysis to happen.
Big wire, short runs, few connections.
supermanotorious
Winchmaster 5000
New River, AZ
it's not going to carry high amperage, it's the charging wire off my converter, it runs through a 30 amp relay for my auto transfer system, I just need it for a clean install, honestly a female quick disconnect with a male piggy back would be perfect
ML-TOYS
long island, new york
Just the female ? What is its mate ? 1/4 5/16 3/16 ?
---------- Post added at 12:38 PM ---------- Previous post was at 12:05 PM ----------
The 8awg fasron connector is a rare find due to amperage. If you are looking for just a 1/4 wide faston to mate with something just get this and use the female. Strip wire to butt against end fold tabs solder and shring tube over.
http://www.ebay.com/itm/1-WAY-FASTON-TERMINAL-CONNECTORS-UL-RoHS-4-Pcs-p-kit-6-3mm-250-14-10-AWG-/162400761704?hash=item25cfd6f768:g:fcUAAOSwu4BV4NPB
really?
first hit:
https://www.fdgate.com/product/100-...e-female-spade-crimp-terminal-connectors.html
3.5mm is a hair bigger than a 8AWG (which is 3.26mm in diameter)
even larger :
https://de.aliexpress.com/item/UXCE...2793715346.html?spm=2114.47010708.4.36.i1hrDc
i you get rid of your stupid American wire gauge and convert it to globally accepted standard measurements, then you'll find them EVERYWHERE!
And yes even us-shops list 3.5mm crimps of all kinds...
bullet connectors are more common (when looking for pairs) but spade... is a google search away as well ;)
PS Sorry.. but it's like watching flies hitting the glass when the window's open...
