Lucky7
I got a horizontal engine NOT running alcohol and my oil is kinda foamy. Just got the engine( its on a snowblower). The engine had no oil in it because the crankcase seal was removed. I filled the engine with sae 30 and let it run for about 20-30 seconds. Then turned it off and checked the oil. It was lower than before but not enough to cause damage. It was foamy like when you pour new pop into a glass and you get that foam. My dad says there could have been moisture in the tank which could have been a possibility because the engine was sitting for a year or two. What should I do. Sorry for hijacking your thread.
