flywheel trouble
Tony
Dafter Michigan
Yesterday i was riding my mini bike when it lost power. I took off the shroud and turned the flywheel by hand. As the magnet passed under the magneto they touched each other. What does this mean? Is it a sheared key? Also the magnet looks like it screws in to the flywheel it isn't built in to it.
thanks Tony
Kaptain Krunch
Pro Junk Collector
vermont
You need to gap your magneto, get a set of feeler gauges if you dont have them already, your manual should have specs for what the proper gap should be. You key may be sheared but i doubt it, you can check if you want but that wouldnt cause the magnet to hit the magneto.
Tony
Dafter Michigan
Only part of the magnet hits it, not the whole thing. I don't think the gap would mess up all of a sudden would it?
Affair_driven
BULL DETECTOR
Wolf Point, Montana
Wrong thickness can cause timing problems.
Invest in a thickness gauge set. Cheap enough and will last forever and is much more professional.
They are used for much more than setting mags.
Ring gaps, points, valve adjust, etc.
