flywheel swap
Soapbox kid
Durham, North Carolina
While surfing I came across someone saying you can put a Honda flywheel on a Predator with a little Modding.Is this possible & has anyone tried it?? Idk I may try it if it's remotely possible. Any comments as always will be respected.
Soapbox kid
After surfing all night & a phone call or two.I found that this swap won't work on a Predator but will however work on all other clones.So if u have a clone u don't have to spend the extra money u can use a Honda flywheel.
rmm727
Brookville, PA
Personally, If I had a clone (not a Predator), I would buy a King Billet Steel Flywheel or the PVL cast flywheel instead of a Honda wheel. There both only $60.
rmm727
Brookville, PA
The PVL plywheel was spin tested to 17K rpm without failure. It really is a nice part.
Soapbox kid
Well to be honest I was going to buy that one that's the honda flywheel I was talking about & at the same time looking to find a cheaper way for everyone wanting to know.
rmm727
Brookville, PA
It doesn't get any cheaper than this. Unless you can find a GXV Aluminum flywheel (like NR Racing sells) off a junk pushmower.
