Dangerouse-Hobbbies
I am resurrecting an old Manco that has a Blue HF 6.5. I am a bit of a gear head and have a decent knowledge base when it comes to mechanics but I am new to tweaking small engines. So my question is are Briggs & Stratton flywheels interchangeable with my Greyhound? I have found a couple of stock aluminum flywheels for a Briggs & Stratton engine (Animal ) and I would like to know if they will work on the Clonda. I have read the sticky about the flywheel exploding issue (or Non-issue ) Spit happens.. hehe. However I would like the quicker reving the aluminum flywheel will add if i can do it on the cheap. I am not looking to spend too much on the engine as it is just a casual fun kart and I'm sure it will be dangerous enough when I'm finished.
The taper &, possibly, the depth will likely be different
