I know this isn't exactly a garden tiller forum, but we use similar engines so maybe someone here can help.
The v-shaft engine on my mid-70s tiller is beyond futzing with. It's dead, kaput, finished, not worth the money.
I have an extra v-shaft engine that physically fits onto the tiller, but without the blade on the business end, the aluminum flywheel isn't heavy enough to prevent kickback (or so I'm told is the problem... the key is in tact, the shaft is not bent, the fuel is fresh, the carb is factory set with no adjustments). Even when I manage to start it, the engine idles EXTREMELY rough and won't respond to the throttle control unless I stretch the gov spring beyond design limit.
I found an iron flywheel on ebay that physically fits this engine, but the magnets are laid out differently than the aluminum one so I hesitate to buy it. Specifically, the aluminum flywheel has 2 magnets on one side and three on the other, each set 180deg from each other. The iron wheel only has the 2 magnets on one side, no other magnets anywhere.
So my question is, in an electronic ignition, does the coil care about the magnet configuration on the flywheel? If I bought the iron flywheel would it work with my coil, or would I have to buy a different coil to go with it?
Or am I barking up the wrong tree here? Could I keep my existing wheel and fix my problem with an offset key?
