u500771
Because i have summer break and probably will be working on my go kart almost every da, I‘ve decide to start a little build log. Today was a pretty good day because i found the stationary engine version of the engine i already have (the main difference is the oil pan. On the stationary one it has mounting bracke in the corner like an old grinding machine or vice). I quickly bought it and picked it up. Gianni and I ha decided that we completely disassemble the two engines and build one for the go kart with the better parts and one out of the remaining parts to sell again. There came also a fan housing with the new engine, so i don‘t need to improvise that myself.
Here you can see the new oil pan that doubles as mounting points (the old oil pan is the silver thing with the gasket in the top left corner).
Those are the partly disassembled engines. The one on the right i‘ve bought last year and its cylinder block/head and valves are in way better condition than the one i bought today. We are going to use the block, head, valves, pistons&connecting rods and the camshaft from this engine. The oil pan, flywheel and the crankshaft will come from the other one because it has almost the same ignition than the mofa‘s we have in Switzerland (those are small 50cc motorcycles that will do something like 19mph and you are allowed to drive them with 14). The next thing to do is taking out the crankshaft of the engine i bought today and disassembling the one i already had. I‘m also going to remove the rev limiter which is set at 3000 rpm.
Here you can see the new fan housing. Its made from cast aluminum and i think I’m going to polish it before i the go kart is finished. My hand also gives a little bit of comparison on how large the engine is.
On what chassis/frame would this engine look the best? Please tell me your suggestions
