https://web.archive.org/web/20001020034424/http://www.dynocams.com/archives/tech/002.htm
I've tried to explain this a couple of times. Unfortunately I don't think I did an adequate job. This old tech article from Dynocams does a much better job.
I think it's important for flathead guys to understand this because these cams show up frequently on Ebay and other places.
If you look at cam spec sheets, they often mention the need to weld the exhaust lifter bore. Because of the way these cams operate they are hard on the block.
Hence the term "block breaker cam".
https://web.archive.org/web/20001020032127/http://www.dynocams.com/archives/tech/001.htm
