flathead briggs cam
shanmillerace
I installed a .233 lift racing cam lined up marks installed a hot coil and the engine will not fire and does have spark what is my next step?
Russ2251
AZUSA:Powered by LAWN-BOY
Should run for a short burst (seconds) if everything is good.
I would suggest trying again.
Verify timing, valve lash, and compression.
Can you supply number on spark plug? I ask because resistance plugs can cause ignition problems in modified engines.
shanmillerace
The plug is you basic briggs plug I repaced cam with the stock cam and it fired right up, how do you check valve lash as I am new to this type of build.
Russ2251
I strongly recommend learning the basics before getting involved with this kind of advanced upgrade.
A valve gauging tool is needed along with a feeler gauge set.
Valves should also be lapped before doing anything else.
Behind the breather cover you will find valve stems and tappets. The gap between the two pieces (valve stem and tappet) is valve lash and is checked with feeler gauges. The valve lash specification(s) should be indicated with paper work you received with cam.
shanmillerace
Briggs 5hp engine trouble
I have a briggs 5hp engine that is backfiring through the carb with a puff of white smoke and won't run. I have set valve lash, replaced the diaphram any other ideas. Thanks:surrender:
