first Yerf (3202 I believe)
ikenread
Hey guys (and gals),
Background:
This is my first post, but have been reading quietly from the sideline alot lately, and alot of users here are very helpful.
Anyways...I bought my first go kart just this week, and it needs a little work (hopefully just a little), but for $110, couldn't resist. I've attempted (read destroyed) small engine repair on my dads push mower when I was a teenager, but I never was successful (of course I didn't have the means to pay for parts and / or the correct tools either). This kart is for my son, who sadly enough will not be big enough to drive it alone for a few years - oh darn....like I said though, this is for uh....him, ya.
Kart details:
Yerf 3202 (based on pictures from yerf site)
Manufactured 2006 (based on emissions sticker on engine which also shows a yerf SN - assuming it is original)
Needs - seat bottom, carb rebuilt, Driver unit, chain reattached, and maybe some bending / prying on a spindle to try to squeeze a little more life out of it.
I saw the motor run for all of 10 seconds when I bought it, but it quickly sputtered out, and fuel leaks slowly through the air filter housing
question(s):
1. Am I crazy thinking it should be "a little" work
2. I'm very happy that I found a hole in my float when I took the carb apart (hear fuel sloshing in it) - hopefully when I get my rebuild kit in, the leaking fuel issue will be in the bag.
3. I think someone hit the right front into something, because that tire rubs on the frame when turning the wheels right. the spindle (not sure if I'm calling it the right part) looks bent
4. are the rear shocks any different than the front on these things? my rear ones seem really stiff...actually, they were stuck until I started jumping up and down on the back of the thing - finally broke loose, but still stiff feeling.
guess I'll have to wait for my carb kit / driver to come in, and hopefully I can get it to run enough for a test drive.
qtband
St. Louis, MO
Welcome to the forum! It took me 54 years to get a kart. In the past year, I've bought, owned, sold about 25!
Make sure your carb kit comes with a new float. If not, you need a new one or if yours is brass, you can solder up the fault. Either way, it should be an easy fix.
Hope your son (?) likes the kart!
ikenread
I ordered a bunch of stuff separately...float, needle / seat / gasket kit, primer bulb, intake gasket, air filter.
current primer bulb looks weather cracked...not sure if that affects the carb or not...oh well, new one was like $0.90 I think, and already paying flat rate shipping on the rest of the stuff.
My son just learned to ride his power wheels quad the other day, and chased me around on my riding mower....I feel the go kart is a little more appropriate for spinning in circles than my mower, which at the end of the day...has its own job to do. At least that is my excuse for now...if it is ever invalid, I'll just come up with another excuse to have the go kart :D
edit:
also, the governor linkage is missing (from governor arm to carb)....any harm in just leaving this off?
ikenread
Thanks, I'll try to get some better pictures soon...the couple times I've been out there with it, all I had was a dumb crackberry (thing hardly makes calls let alone anything else).
Wife just called a little bit ago, and said carb parts came in though :D
Welcome to the forum.
For $110, it wouldn't matter if it needs a total rebuild; you got a great deal :thumbsup:
You'll probably find (don't quote me on this) that the rear shocks are harder than the front because they carry more weight. Try putting a coating of oil on the rears shafts & work the heck out of them, thet should loosen them up.
As for everything else, as stated above, we'll need pics to determine what's wrong...
Welcome to the forum. The work you have detailed is not too much to do. It sounds like you have got most of the parts you need to get it going now. Have you bought some chain and the driven half of the TC yet.
ikenread
the driven was already on it when I bought it - Don't know how to tell condition of this without waiting to see what happens when I try to run it.
attached pictures:
2 pictures of right(looking from driver seat) spindle (damage really hard to make out in pictures - maybe if the camera had 2 eyes like I do, maybe it would be more apparent.)
1 picture of left spindle for comparison
1 picture of front
1 picture of rear showing (what I believe to be) the governor arm
Yeah, that's just a bit of extra caster, don't worry about little things like that :worried2:
But seriously, that's a pretty easy fix: Find yourself a bolt long enough to go right through the spindle bracket. It should be fully threaded so you can wind a nut all the way down. If you can't find one, threaded bar will work.
Now, remove the spindle & place the bolt (or threaded bar) into the lower bracket, then run a nut (or two) down so that the end is just below the top bracket & tighten the nuts. This will act as your guide to where you need to bend the bracket to.
Now bend the top bracket until the hole lines up with the bolt. A pair of locking pliers or an adjustable wrench across the bracket will work. Try to avoid using hammers (they may crack the metal) or heat (it will weaken the metal)
If anything is unclear, let me know & I will clarify for you...
ikenread
too hard to tell from the picture, but it is twisted a little as well...the only reason I noticed it in the first place, is that that tire rubs the corner of the frame at about 80% right turn --- about 20% extra steering from left turn where wheel squeezes ~1.5" inside of frame corner.
