Pretty good, maybe need to work on your starts a bit as you can see where theres a gap.
Pin hole was at the stop. Otherwise, decent weld.![]()
To keep rods from sticking with a cold start, I'll usually scrape it a few times on a piece of scrap steel (easy to do if you're grounding the table you're working on) to get it nice and hot before I start. A quick tap where you want to weld will usually get it going from there.
It's tricky to strike it and lift just enough to maintain the arc and land it in the right spot, although some of the more experienced guys can do it without a second thought.
I've actually tig welded a bit at my friend's shop, but only with aluminum. To me it seemed like one of those things you could do fairly easily if you just took your time, but needs a lot of messing around with and practice to be able to do it quickly at all.
Thanks guys. Some days are better than others. I also agree with Badot about scraping the rod on a piece of scrap at the start to get the electrode hot. I find that it stickes mostly when it is cold. It is a bugger though, cos when you do eventually get it off, some of the electrode has crumbled at the end, and it is then hard to use.
than trying to weld with damp rod.
