First Thread!
treyfus
Augusta GA
ok guys im in need of some knowledge. i have my kart partially assembled and had it up on jackstands and turned the motor on, the rear was off the ground, the torque converter woulnt quite go into a neutral state so i assume i need to loosen the belt a little bit. no big deal. but the motor did not respond to me hitting the throttle at all, but the choke did wonders! i am puzzled by this. also, it backfired a good bit when idling after it got hot. is this probably due to the kart being off the ground? Thank you for your help.
treyfus
Augusta GA
i was holding the lever that normally would control throttle on the motor, i loosened the nut so it is in variable speed, but it didnt really seem to do anything compared to the choke lever right next to it.
treyfus
Augusta GA
Ok i'm stuck.the engine is idling higher than I need it to and engaging the torque converter. I fiddled with the governer arm but when I got the RPMs low enough there was no throttle response.this is on a 16HP blue clone.any suggestions? The pulleys are the right distance for the belt to
treyfus
Augusta GA
update: frame is complete and at paint shop for a complete sand/prime/line-x spray job. im excited i think the bedliner look will be very cool and unique. i got some diamond plate on the front and floor on my buggy as well. final assembly to be done this weekend. anyone here have any thoughts on my bedliner paint job?
treyfus
Augusta GA
I have completed my buggy project one week before i graduate. good timing. What do you guys think?!
treyfus
Augusta GA
I showed my buggy off to the dean of engineering! He was all giddy and wanted to keep it at the school to promote the program haha. heres a pic. its going in the news and school website:wai:
dobbo049
Awesome! :D
Still think it looks fantastic! and glad it worked out so well.
Have a good graduation!
Speak to u soon :)
treyfus
Augusta GA
yes he did. he had a huge grin the whole time haha. he even hopped the curb with it. i took it out last weekend. that thing FLIES in the woods/ field. its amazing how something that feels so-so on the street seems like a terror off road haha. you get tunnel vision at top speed. Thank you guys yall have been a big help. next will be a race chassis with a ninja motor. but im still messing with this one, since the rear section is totally seperate i may put a v-twin on a new rear frame with one fat motorcycle tire, that would be fun with the same front end :) the current torque converter needs to be cleaned after every ride (it locks up after getting a little dirty) im going to make a little aluminum cover for it.
