First post / Manco Interceptor
Sidponco
Hi All
Just got a craigslist deal on a Manco Interceptor. The cart sat for 4 years and needs everything lubed.
The engine runs great...BUT
Even at low idle, the cart wants to move. I pulled the clutch cover off and it has a centrifigal setup. Is it worth messing with this clutch to get it to work properly, or just order a new one.
Really want to make it safe before putting my son in it.
Thanks!
Blazkowiez
Kart Aficionado
Houston, Texas
Your idle may be too high, your clutch might be worn out (springs) and having trouble disengaging, and/or you may have a stuck throttle.
DCProductions
Cockney Ragamuffin
Louisiana, USA
:iagree:
Also, those are some itty-bitty tires! I like the color of the wheels though. You may want to check the clutch bushing too while you're checking the springs.
Sidponco
OK Folks
New clutch installed....carb all cleaned out and it runs great!
The throttle and governor springs are rusty and ready to snap. Will order those from Subaru Robin. This little thing is FUN
Sidponco
Hi Folks
Broke out the Kart yesterday and found that it needs new tires for sure.
Now it has 4.10/3.50-4 tires on it. Can I use a taller tire? Do I have to replace the rims to do so? Where is a good place to get tires/rims?
Thanks!
Sid
Not too sure if the work on the same rims, but if you use taller tyres (bigger that 10%), you might have to look at regearing your kart. You should be good though, cos those tyres you have on don't look stock, they look a bit on the small side
