Ok let's see.
Removed obnoxious stickers from compressor, and rearranged brand name for something better
I want to take the governors out of the (2) 5HP Tecumseh's, so I figured I'd take apart the 6HP one that isn't working yet as practice. As you can see, the governor already had teeth broken off. The inside housing of engine also had a big scratch as if the governor had already blown up against it at some point. I didn't see any parts floating around, but maybe they got dumped out with the oil, I wasn't looking. I had to just break it apart to get it off. I've ordered some gaskets and new drain plugs.
ONCE AGAIN, I need to give PB Blaster high praises. The drain plug was so tight, it was bending my Allen wrenches. I sprayed PB Blaster, waited 15 mins, still nothing - BUT - instructions say to tap and repeat if it didn't work. So I tapped it around with a hammer, resprayed, and 15 mins later it was loose. This stuff is awesome.
Finished painting the candy apple red. Just need to take it out of the booth and inspect it in the sun and do some touch ups, then I'll hit it with the clear coat.
Last pic is a 2" thick ribeye, cooked in sous vide at 131F for about 2 hours, finished in cast iron with butter, with white cheddar mac n cheese.
