First kart project
fast92rs
Old Bridge, NJ
New caliper installed
Poboy kartman
Senior Moments Member
White Settlement Texas
Those welds are still looking a bit short to me......:lolgoku:
Where did you get those spindles.....in the back of my mind. ...I vaguely remember someone looking for those........
BTW.......Lookin' GOOD! !!!:thumbsup:
Half-breeder
"Edit" button removed
No, I asked to confirm my suspicions; I predict your steering will need more work; have you seen this thread?
I was just bout to make a simular comment...
Live axle w/(what looks like) no caster/camber/Ackermann w/ front facing arms?!?!... dont leave the yard if you like turning(it woulda been different if it was a dead axle). Turning will be CONSIDERABLY difficult/different once you hit pavement. High speed turns will be out of the question and I cant even predict the expanse of radius itll take to get it 180* turned.
... after reading the link Fab posted you can check this one out to fix the Achermann, w/out starting over.
fast92rs
Old Bridge, NJ
I going based on the plans. I tried to see if I could reverse the spindles but this kart is designed to have front steering. I will see once the tires are on what adjustments I will have to make for toe and caster.
