Hello there, I am new here and I would like to thank you for taking the time to read my post.
I am about to buy all the parts for my go kart and before I go out and spend all that money, I would like to know if all my parts are compatible and if I am missing anything. Also, if you know of any cheaper alternatives that produce similar performance, that would be appreciated. This is a single wheel drive assembly. I also had a question on how the free wheel would be attached; would I need to use a wheel hub as I have with the drive wheel?
Engine: Briggs & Stratton 900 Series OHV Engine
Clutch: Hilliard Extreme Duty 3/4" Clutch 12T #35
Sprocket: Sprocket #35 72T (2-13/16' Bolt Circle)
Wheel Hub x2: Double Flange Wheel Hub with (4) 5/16" Bolts on a 2-13/16" Circle (Includes 5/8" Bearing)
Brakes: Steel 4-3/16" Brake Drum (4") + BRAKE BAND 4-3/16" (4")
Spindles: Complete Spindle Set - 5/8"
Steering Shaft and Pitman Arm: Steering Shaft Kit
Length of Shaft: 25" (600545)
Tie Rods x2: 3/8-24 Tie Rod Kit
Length: 11" (420011)
Chain: #35 x 40" EK Kart Chain
Tires + Rims: 13 x 5.00-6 Carlisle Tire Split Rim (260120)
EDIT: I'm not sure on the tires as I feel like they are too big and I realize that I would need hubs for the front.
Steering wheel, Throttle and brake pedals, frame, and seat will be home built.
Again, thank you for your time. If necessary, I can post the plans I have drawn so far which doesn't include the motor mount.
