First go cart
Lawes12
I am new to this forum and new to go carts too. I received a yerf dog spider box chassis and I bought a LCT 291cc engine with a torque converter on it. I have 10 tooth drive sprocket and a 40 tooth axle sprocket. My question is it hauls when jacked up, but when I get in it (230 pounds) it won't move. Lol Do I need a different gear ratio? All drive components are new. I was hoping to get a final mph of 30 or more. Any help would be greatly appreciated!
Welcome to the forum
You have a gear ratio that is waaay too high. It is 4:1 at the moment. We normally recommend a 6:1 ratio to start off with, but this depends on tyre height as well. What is the diameter of your rear tyres? If they are larger than about 15", then you will have to gear even lower, to about 7 or 8:1. Post some pics of the kart so that we can see what you are working with
cavfire
auburn, georgia
Definitely a gearing issue. For starters the spiderbox came with a Howhitt 150cc with it's own cvt and output ratio built into the motor. Because of this buggies running a GY6 will have a smaller rear sprocket than a buggy with a industrial engine. You should look into putting a 60t axle sprocket on.
You say you have a torque converter, and I just want to make sure you're referring to a Comet 40 and not a centrifugal clutch. You can just about hang it up trying to use a centrifugal clutch on something the size of a spiderbox.
Lawes12
Thanks guys the tires are I think 17 inches high. I will get pics soon. And yes I am using a torque converter I do believe it is a knock off comet tav 2 torque converter. I was going to try me use an 8 tooth drive sprocket and a 60 tooth axle sprocket? What do you guys think? Good place to start? Also do you guys recommend removing the govenor gear or no? Anything I need to do in order to do that safely? Thanks!
---------- Post added at 06:18 AM ---------- Previous post was at 06:17 AM ----------
I think that would put me right around a gear ratio of 7.5:1?
---------- Post added at 06:21 AM ---------- Previous post was at 06:18 AM ----------
Given the new gear ratio and my cart info how fast do you guys expect the go cart to go with me? My engine said Rpms are 3850.
Lawes12
Ok would there be any performance upgrades you would do to a bone stock engine?
Probably a free flow exhaust and intake, but other than that i wouldn't do anything. That is just me though. I know a lot of other people that would do more.
Just remember that if you do remove the governor, you MUST remove all the internal parts of the governor as well. You cannot just bypass it. Those internals can cause havoc inside your engine if they then come loose
You do not have to upgrade anything internal if the governor is removed. The stock springs will cause the valves to float at about 5000rpm's, so the engine will not cause any failures. As soon as you want to upgrade the springs to say 18lbs or higher, then you will need to get a billet rod to avoid potential engine failure
Lawes12
Do you know any place that has intake and exhaust for my engine? What do you recommend
I do not know where you live, so i cannot recommend any place to you. This is where filling out your profile comes in handy. I could tell you where to get the goods here in South Africa
Assuming you are probably from the US, you could try looking at this thread
http://www.diygokarts.com/vb/showthread.php?t=1180
Lawes12
So I have decided to run a 8 tooth drive sprocket with a 64 tooth sprocket. I think the ratio should be around 6.75:1. What do you all think? I had my wife drive it she is maybe 130 pounds and it took off like a banshee with her and my girls in it so maybe around 200pounds plus cart I think if I go this route I won't have any problem at all. Any problems you guys see?
Seems like a good starting point. If you don't like it you can just gear lower
cavfire
auburn, georgia
Shouldn't be any problem at all with that gearing on a 291cc engine. That would put you around 32mph in a perfect world, meaning the motor was turning 3850 rpm and factoring in the 10% overdrive. Should have pretty decent acceleration too.
Lawes12
I just noticed that my brand new belt is a little tore up? Is that from improper gearing or?
