sied_wayz
Kepler 597cc
My first go kart build! I've been wanting to do one for years and this is the first chance I've ever gotten. I took a welding shop class this semester at college. I bought plans from spidercarts for the scorpion design and sort of made my own touches to it. I haven't finished it yet but here is everything so far!
This was the first I really did. I started by welding up the rear frame. It actually changed quite a bit from what you see here. I made some bad measurements because I ordered different parts from what the plans called for.
Here is the lower subframe of the front end sitting next to the rear end.
Here is the building of the chair frame. This part sucked. I needed a 67 degree cut and my saw only goes to about 50ish. So I had to do a lot of grinding and a lot of stacking beads to fill the gap but it came out sturdy!
Here's the engine I'm using. It's a 212cc 6.5hp predator from harbor freight. Atm it is stock, but I love to build engines. I teach an engine building class at my college and we go from small Briggs engines up to the 454 I'm building now. My plans for it are a new cam and a metal cam gear to replace the plastic one, 26lb springs, aluminum billet flywheel, exhaust, and intake, and ported head. That's about all I really want for now.
After UPS Royally pissed me off and two weeks passed by, I finally got a big box of parts!
Parts assembled
Here is the update on the rear frame with one of the hangers welded in place. (Vertical welding is my specialty)
There's more to come! I still have to decide between a torque converter and a clutch. I also still need to decide on a suspension set. After that, all I need is a steering column and pedal cables and then it all just comes down to installation! I'm so excited for this kart.
Parts assembled
Ok you guys have beat the gearing thing to death, So... With all those engine mods billet parts etc. Why no mention of removing the governor, that will get you 1500-2000 more revs equaling a higher top speed for the back roads.
