Filing flywheel key.
jamyers
Buffalo Gap, TX
EDIT- (again, LOL) I couldn't take it anymore... I checked a few 'wheels I found floating around.
:wai:
MWU-HAHAHAHahahaha!!! I *knew* somebody was going to check a flywheel, I just knew it! :cheers2:
I also asked the counter-guys at my local small-engine parts place this morning (as I got a new sprocket for my 8hp Briggs starter), they said that as far as they knew all flywheels are just balanced by themselves like we're thinking (aka zero-balanced).
Well, it does make sense. You break a 'wheel, you just replace it. You wanna race, you just go buy a nice, purty billet 'wheel. You want to run a lighter 'wheel? You swipe one off a mower or smaller engine and run it. Never heard a negative comment regarding balancing.
I read a lot of service manuals- and have NEVER seen any reference to a need to have a replacement 'wheel rebalanced with the reciprocating assembly.
To the extent of my knowledge, the mower blade is not related to engine balancing. However- a mower (and some other implements) use a much lighter 'wheel as the blade adds a lot of rotating mass. Running a mower engine without the blade has some interesting characteristics. A technique is required for starting the engine, as it can kick back and rip the handle out of your hand, and/or break the rope. Rotating mass is reduced, resulting in an engine that can accelerate more rapidly, but can be more subject to lugging in the low end.
