Fat tire leaning trike with single sided swing arm
hodala
Taiwan
Very nice!! Could you maybe show us a few more pictures of how the rear wheel is connected to the frame
Let me show you some of mass production types so you can compare what different
hodala
Taiwan
My type is easier machining for DIYs
First weld 3 parts then do bearing holes lath machining, at last weld all parts togather
hodala
Taiwan
Just do this detail illustration guess you people like to see
Shock absorber bushes no need in CVT(Torque converter) case
Jaymo
That is amazing. I like the idea of a reverse trike that can be used off-road.
hodala
Taiwan
scooter Ruckus seat & engine shock absorber mounting
These motors dont like to be rubber mounted. You will have chain/belt issues that will likely derail the chain or belt. Mount the motor right onto the frame of the trike...
hodala
Taiwan
Chain train rigid mounted,belt problem depends on how flexible between drive and driven pulleys,it won't fail if the engine not moved too much displacement when the clutch engaged(low speed high tension)
I don't think you quite understand... You cvt is supposed to have a fixed distance between the shaft centers hence most if not all are hard mounted...
Having a rubber mounted motor now causes that distance to not be fixed under load or other factors of riding... Bumpy, inclines ect.
hodala
Taiwan
That"flexible" means enough to absorb engine's vibration but not much visual displacement
Chain/belt drive allow not so accurate alignment and center line distance is ajustable
I had ever used same kind rubber mount on a small engine aplied with timing belt drive that movement much more than this time
I had been in motorcycle company in charge of CVT match for new models
