Factory driveline question
Specialk
Good morning,
I just joined the site after lurking for a bit. I recently bought the kids a Carter bros full suspension go kart with a 6.5 tecumseh. When I bought it, the guy said it used to be fast and take off good. But when he replaced the clutch, it only went for like a week before burning up. After I brought it home, the kids were able to ride most of the weekend on the "bad" clutch. Then it started slipping. I took it apart and attempted to see if there was anyway to make it grab better, but I didn't see a way. I am on the verge of buying another belt clutch, but would much prefer a TC.
The crankshaft has a belt clutch (centrifrugal clutch with pulley instead of sprocket), that runs to a larger pulley on a jack plate. The larger pulley is attached to a shaft that comes to the left hand side of the cart and drives the live axel. I have been looking, but haven't really seen that setup. I was wondering perhaps if the cart came with a TC, and when the belt wore out, needed adjustment, or whatever, the driver pulley was replaced with a clutch.
Is there anything special I should look for on the larger belt pulley to confirm or deny my suspicions?
The model number for the cart is on the driver side just in front of the seat, however, it is unreadable.
hello and welcome.
I think were going to need pics for this one. The PO might have thought the belt clutch will work on the TC driven and it might have worked, but no way to tell with out pics.
A guess???
Hi and :welcome2:
Since many people mess up pulleys and driver/driven units, please allow me to ask for a picture.
What you describe sounds very much like a TC setup
that might have been replaced with just pulleys of course by some PO.
you said jack plate.. and that's why I think it was a TC once.
I've seen jackshafts for pulleys and TCs, but plates I've only seen for a TC so far.
Specialk
I will admit to some confusion regarding jack plate/ jack shaft. The "driven" pulley is mounted to the frame and has a shaft enclosed in a bit of tube, before exiting with a sprocket for a chain.
I will try to take a pic as it is set up as soon as possible. Hopefully I'm right and it just needs a driven pulley instead of a belt clutch.
I think we have a classic problem here. It comes town to a lack of understanding on the part of the previous owner. I'll bet my last chocolate chip cookie that your machine exited the factory with a CVT (torque converter). At some point in it's life (VERY likely due to a lack of maintenance), it began malfunctioning, or even ceased to function altogether. So- rather than repair it- he maybe didn't know how- he replaced it with a simple clutch and pulley configuration, figuring it would work.
The problem here boils down to the fact that a CVT goes well above and beyond a simple centrifugal clutch. Indeed it performs clutching duties, but also varies the machine's drive ratio. It engages at a reduction in the neighborhood of 2.5:1, and works its way up in ratio as the machine accelerates. The lowly centrifugal clutch can do no such thing, leaving you with one fixed ratio. Now-
One fixed ratio CAN work for you (albeit not as well as a variable ratio) but the problem there lies in the ratio that was selected to replace the CVT system with. Every time we see this, the machine is geared too high. Gearing that works with a CVT will invariable be too high for a centrifugal clutch setup. When something is geared too high, the clutch ends up slipping more than it should. Aside from the lack of torque, it creates heat. Heat kills clutches. So now you're at THIS point.
Best bet? Pony up the cash, and go back to using a CVT.
Specialk
Ok, here's a pic. Previous owner now states that he never changed clutch and this is original.
that worked.
for easier access
and a permanent availability:
So, now, those are indeed both pulleys, no torque converter,
neither the driver nor the driven pulley.
belt tension looks good enough from what I can see..
ratio (since it's geared down further by the sprocket ratio) looks to be good enough too.
the way it is, it looks like the jackshaft is made to hold a series 40 TC driven.
Since you don't need a series 40 (a series 30 will be good enough and much cheaper)
you can surely try that but make sure you mount the cam of the driven towards the wheel.
Specialk
I finally found the model number. That is a factory setup. From what you guys can see, a tc should pretty much mount right in, right?
I'm not too sure, depends on the driven pulley diameter,
if it's larger than 6" then yes, it should be close to a "drop in" replacement.
otherwise you might have to cut the plate
Half-breeder
"Edit" button removed
I wouldnt go w/ a 30series... Id go a 20series... reason... 30series has an asymetrical belt... 20 has a V shaped belt... V shaped belt means the driven can be run flipped around vs the 30 has to face same direction(that was the issue I had to deal w/ on my TAV2... hence why my TAV plate sticks up, instead of along side, the motor, like most/all run it... I also run a Carter 'rear' JS setup...)
Specialk
The pulley is currently 6.5. I think I could go 7 with no issues. Assuming that a 20 or 30 series is a direct drop in, would I still need to change the sprocket?
I don't know your sprocket sizes, nor wheel size,
but since you said it was working properly before the clutch went bad..
NO, just run the same sprockets.
If you feel having too much torque, you can increase the smaller sprocket a few teeth (2-3) and try again,
that will drop the take off torque and increase the top speed.
