Good morning,
I just joined the site after lurking for a bit. I recently bought the kids a Carter bros full suspension go kart with a 6.5 tecumseh. When I bought it, the guy said it used to be fast and take off good. But when he replaced the clutch, it only went for like a week before burning up. After I brought it home, the kids were able to ride most of the weekend on the "bad" clutch. Then it started slipping. I took it apart and attempted to see if there was anyway to make it grab better, but I didn't see a way. I am on the verge of buying another belt clutch, but would much prefer a TC.
The crankshaft has a belt clutch (centrifrugal clutch with pulley instead of sprocket), that runs to a larger pulley on a jack plate. The larger pulley is attached to a shaft that comes to the left hand side of the cart and drives the live axel. I have been looking, but haven't really seen that setup. I was wondering perhaps if the cart came with a TC, and when the belt wore out, needed adjustment, or whatever, the driver pulley was replaced with a clutch.
Is there anything special I should look for on the larger belt pulley to confirm or deny my suspicions?
The model number for the cart is on the driver side just in front of the seat, however, it is unreadable.
, that took me a while to read (had to read it out loud)
