Extra long axles
billlaws
Somerset England
I'm building a fairly sizeable kart with a 250cc 6 speed manual bike engine. It will have independent suspension up front and either solid or partly sprung rear end. I want to make this kart wide and low however I'm struggling to find a rear axle wide enough.
I'm after a 30mm axle thats at least 48" long.
The longest I can find at the moment is a 44".
Has anyone ever just bought some precision round steel and used that? Also what did you do about cutting the keyway?
thanks
Will
KieranM
Doin It!!
Kilkenny, Ireland
I have built a machine (not really a kart) but had to hold the same weight. I used silver steel, it was hard as hell to machine but it can withstand alot of weight. You could also get a piece of bright mild steel, machine it and then harden it by bringing it to cherry red and cooling it in oil, not water. The keyways can be cut by a milling machine or a dremel (small hand grinder) with a cutting disk. Make sure you support the axle with various pillow block bearings so as not to be putting strain on one area.
newrider3
Colorado
Have you thought about independent suspension in the rear? Junkyard components (CV axles) can be sourced relatively cheaply, depending on your local prices.
gcarter95
Ottawa, Ontario
I bought a bar of 1018 steel and had a friend mill the keyway for me.
You should be able to find keyed stock at an industrial supply place that sells driveline components, though.
modelengineer
Lord of the noise
Sydney, Australia
I used a piece of 4140 ground high tensile chromoly. That's the stuff you should use for an axle, especially a long one.
I used 1 1/4" diameter which is just a bit more than 30mm.
porsche930dude
Upstate, NY
its pretty easy to cut keyways with an angle grinder. Clamp a straight edge on i use bed frame because its hardened steel. I use a thin curf wheel and do one side at a time then cut out the middle and work on the depth.
billlaws
Somerset England
I'm thinking I'm just going to do a simple swing arm arrangement. Probably with the engine on the actual swing arm.
