Step into the motorcycle world, and look up "forward controls". Basically you'd mount a new shift lever in the right location and run a simple linkage.
I don't think you want to run a jockey shift/suicide clutch on this. You're already going to have your hands full (so to speak) with all that power. The typical jockey shift setup requires that you shift with your left hand, and clutch with your left foot. Obviously, you have to take your hand off the handlebar to shift. Less obvious to the inexperienced, is that you cannot put your left foot on the ground while idling in gear, and if you need to have your right foot on the brake, then you can put NO feet on the ground! This is where the whole "suicide clutch" term comes from. With experience you can manage it, but when you're new- well- make sure you're padded...
You could make the jockey shift a little less hazardous by mounting a clutch lever right on the shift handle, freeing up your left foot completely.
