Exploded governor
Cjhoward78
Just thought I'd post thisImageUploadedByTapatalk1360071765.595842.jpgImageUploadedByTapatalk1360071780.308998.jpgImageUploadedByTapatalk1360071797.739510.jpg
Old tec 6hp power sport. Got it like this. Broker oil dipper, gouged crankcase, damage to camshaft. This engine still ran and I found the pieces laying in the crankcase. While I'm at. May rebuild this motor soon but I hate the carb.ImageUploadedByTapatalk1360072069.544315.jpg
It takes forever for this engine to idle properly. Is this common to be cold natured or does it work good w a fresh engine. It starts right up, I like carbs w a choke personally.
Cjhoward78
I got a 212 predator on my kart. Just thinkin I could put this tec. Motor on my mini bike. Probly cost close to 100$ to rebuild so scrap:eek:
Nodroz
Belgium (Europe)
How badly damaged is that camshaft?
Any idea what has caused the governor to explode? Did the previous owner bypass the governor?
What's wrong the carburetor btw?
Cjhoward78
Cam is dinged up on the shaft but lobes look fine, pretty sure they by passed governor externally, don't know if dipper broke first or governor internals. Carb o rings on pick up tube leaking I think.
Cjhoward78
Just an example to why u should remove the whole governor if u want higher rpms. This motor would rev out. Just won't idle worth a crap.
Yeah- there, and everywhere else. Been saying that for a loooong time. Feel like a broken record. record. record. record. record. record. rec- you get the picture!
Bluethunder3320
first time i've ever seen this
tecumseh carbs are crap. the engines are decent. if you can build an adapter for an older briggs carb you'd be set.
the hole in pic 2 might supposed to be there? idk i seen some like that
machinist@large
West Michigan, 49331
:lolgoku::funnypost::cheers2:
[Hijack alert!!!]
At least you know what an actual record is (as well as how it can be broken!!). One of the Die-makers at a shop I used to work for was having all his Ebay treasures shipped to the shop so his better half wouldn't find out; his passion was old vinyl. One day UPS had a really heavy box for him (the posted weight was like 65 lbs) full of albums dating back to the 1940's.
The apprentice working with him was totally confused when he ripped the thing open at lunch and had all of us born before 1987 openly admiring his stash. The apprentice was born into a household where they were already declaring CD's to be dead; he'd never even heard or vinyl records. Needless to say, Die-makers being Die-makers, they didn't let the poor kid live it down.
What made it even funnier was the next day: said apprentice told us about his Parents reaction to hearing about someone collecting "outdated analog rubbish". Apparently, his Parents (and him) were of the opinion that when something new came out (technologically speaking) you were supposed to throw the old out and buy all new. When I pointed out that the surface grinder he was running that morning still wore it's WWII production tags, he refused to believe me. I could go on about the trials and tribulations this kid set himself up for, but I gotta quit hijacking this thread......
[Hijack alert now over] We return you to your scheduled thread.......:cheers2:
Cjhoward78
Yes the hole is for the oil up to the valve train. Surprisingly little damage considering what took place at high rpm.
