exhaust flange need help finding
gvfc2
wishing i was living
Tacoma,wa
ok i know i have alot of questions but i dont get them all at once or if i do i forget them when i go to ask but i need help finding an exhaust flange for my robin ex27 as i need to put a new exhaust on for more clearance on my mini chopper. sorry for the crappy pic and drawing.
for those that cant see it or understand it its 3" long by 1 3/8" wide. the center hole is 1". the bolt holes are 1/2" and i dont think it matters but its 1/4" thick. ive tried finding one and cant find one. would THIS , THIS or THIS work for it?
BTW it took me abit for the hyper linking.
anderkart
Surprise Arizona USA
From your drawing I see your bottom bolt hole is offset, so the pipe wouldnt line up (even if the bolt hole spacing was the same) using those briggs pipes in your links.
You could probably just cut the flange off your original muffler and re-use it to build your own pipe.
Or call/email this company:--> http://www.robertsonstorquetubes.com/pipes.htm They sell a couple different header models to fit your engine, or they also sell just the Subaru mounting flange you need for $6.
gvfc2
Tacoma,wa
Ok that's great. It answered my question the best. Now I have another one. Where could I find an air filter adapter so I can get even more clearence and make it look cleaner. Maybe get alittle more power. I don't have a pic for the air filter adapter at the moment as I'm not at home.
ryf
+1 for upper advise, if that doesn't work out or you or someone else cant find one, get a new exhaust gasket(or 2 if the old ones trashed) , spray paint the old ones outline onto a piece of metal and drill out the spots to make your own. this is how I did my Tecumseh's at least.
as far as air intakes the racing guys have all the knowledge on those :)
