ever seen a clutch like this ?
Jim-L-L
South Australia
Hi,
I've bought a cheap old 30mm axle which has come with a oddball combination clutch / main sprocket !
Anyone have any info on these ?
Never seen one before ? I can see the advantage in that there is more surface area, but it weighs a lot ! (cast iron like a car brake drum)
I am soaking everything with a view to getting the clutch and old bearings off with a press maybe next week
Cheers JK
anderkart
Surprise Arizona USA
Nodroz
Belgium (Europe)
There were several diferent brands of axle clutches (similar to yours) used in enduro kart racing back in the 70's/80's. Your pic doesnt show enough detail for me to ID it its brand, but you'll find some info and pics at these google image & search links that should help you out:
http://www.google.com/search?q=axle..._E2QXJgIGIAw&ved=0CAcQ_AUoAQ&biw=1024&bih=532
http://www.google.com/search?source...fp=1&biw=1024&bih=532&bav=on.2,or.r_qf.&cad=b
On a side note...
Why are they using these special axle clutches for enduro races? Are they that much durable?
Sorry to hijack your topic, just wondering. ;) :thumbsup:
anderkart
Enduro karts raced on huge tracks will very long straightaways, so they were geared for very high top speeds. But these tracks also had fairly sharp corners the drivers had to slow down for, that meant their clutches spent much more time slipping than Sprintkarts that typicly raced on smaller tracks with shorter straightaways/lower top speeds.
The larger (drum & shoe) diameters of axle clutches would simply tolerate more slippage without overheating compared to the smaller-diameter engine mounted clutches that sprintkart racers typicly used.
Jim-L-L
South Australia
Wow ! thanks for all the info ! What sort of HP and RPM can these handle, If its salvagable I might use it on my 2013 build off
anderkart
I'd expect they were designed to handle engines in the 20+ HP range.
Not sure about RPM ratings, but clutches like yours held up to the axle RPM of endurokarts going over 100mph with 11" tall rear tires.
