Even more clutch problems....
emudryj
South Florida
Hi guys... just yesterday finished putting everything back together on my carter bros kart...
New rear tires (what a PIA), new centrifugal clutch, new brakes, plugs, new carb, etc...
the problem is (it was there before all this when I bought it) that it may be idling too high.
When I bought it the PO told me that it would need to be run with the choke closed so it would not stall. (dirty carb or so i though)
I assumed that by running it like that he was burning the clutch and killing the brakes (brake band was shoot badly).
I put it all together, it started right away, but at first it was like he wanted to run away until after a few seconds that it calmed down....
I thought that everything was great, so I decided to go for a trial ride.
I'm 220 pounds, and the kart did not have the lower punch I thought I would get with 7.2:1 ratio, 15 1/2 tires.
But that was not my main concern. My main concern was that after 5 or 6 minutes the clutch started to smoke a little bit.
This behavior was exactly the same that I saw when I first bought it and I attributed to all the other "issues".
I know that is sounds strange but in my uneducated opinion it seems that:
#1 the engine is idling too high at start getting the clutch to slip and the kart to try to run away.
#2 It seems that even at full throttle I'm not reaching high enough RPMs to prevent the clutch from slipping. I had 2 wheels on grass and I press the throttle pedal to the bottom and I could not get it to move. I only got the clutch to over heat.:mad2::mad2::mad2:
What do you guys think?
Does it sound logical?
I did not change any of the adjustments at the carb or throttle linkage, so I was wondering if is there any screw to make tighter/looser or wire to adjust to fix this problem.
7.2:1 on 15.5" rear wheels is kind of a stretch for a smaller of 'our' engines (should work well with 9hp, okay'ish with a perfectly good 6.5hp.. should stall on a 5.5 or lower hp engine)
especially if it's a heavy kart..
most Carters on here are two seaters and thus in the "heavier range" when it comes to curb weight.
So yeah, maybe that's the main issue we're going to deal with
but yes, creeping means the clutch is engaged, which can be caused by a high idle speed (or faster revs during warm up/choke)
So, to prevent that easily (during warmup).. lift the rear, place it on some bricks and let the engine warm up that way..
but a perfectly dialed in engine shouldn't need that tbh.
you can't move emans either the clutch is already burned out, or (likely at least the reason for the clutch burning in the first palce)
not enough torque for your weight/gear ratio to get you moving.
that can be one of multiple reasons even a combination of several.. the main three:
#1 bad gear ratio (yours is not great but it seems okay'ish to me from here)
#2 engine is not running properly
#3 engine is way to small for your karts/passengers weight
