ENGINETIC 700 Hydraulic Brakes
cOw
Raleigh, NC
I have just bought a setup for my kart, however one of the pistons leaks. I think I need a new seal, but how would I fix this?
Thanks
... With a new seal...
Okay- More detail? Use either hydraulic pressure (or better yet, air) to blow (gently) the piston out of the bore. Clean up, replace seal, lube with brake fluid, reassemble, bleed brakes.
cOw
Raleigh, NC
Sounds good to me. The guy that I bought them from gave me a new O Ring, which I believe acts as a seal for one of the caliper pistons
Tip: After removing the caliper and brake line, place a folded towel or shop rag between the piston and caliper. Use a blow gun from your compressor where the brake line went, and in very short bursts, blow the piston out. The rag will prevent damage from the piston smacking against the far side of the caliper.
cOw
Raleigh, NC
The caliper I have actually comes apart into two pieces, one pad one each side. It sounds like your tip wouldn't have that happening? Is this ok?
Whatever- the principle is till the same- use some sort of padding to keep the piston from flying uncontrollably and possibly striking something, and use compressed air to move it out.
