When doing a compression test, roll the engine over backwards for a more accurate reading- this way, the compression relief mechanism that makes pull-starting easier does not affect the test results.
I found out that I had a bent intake valve and replaced it. Now it will crank but have a low idle and stalls when the air filter is on or when I cover it with my hand. I am going to change the oil later and see if that makes a difference.
