engine wiring
mailman2000
Ok guys this my first post. I picked up a 49cc 4 stroke buggy go cart for my son. If you keep both buttons pushed in on dash it stays running when you release the buttons it dies any suggestions?
mailman2000
Not sure of brand but there are 2 buttons next to key that must be pressed together to start
Hello and welcome.
As been stated, make model and a better zoomed out pic(s) of the item/machine in question?
mailman2000
Think a bode buggy?
anderkart
Surprise Arizona USA
I might be able to help you figure out the problem, even if we don't know what brand your buggy is :thumbsup:
Most all brands/models of buggy's like yours have a fairly similar electrical system, using either a 4 or 5 wire CDI box. I can see the CDI box in one of your buggy pics, (its located on the frame behind the seat) but I cant tell how many wires are in the wiring harness that pugs into it. Does yours have 4, 5, or ? wires in its plug?
You'll find pics of 2 commonly used CDI boxes at these links for reference, Is yours like either of those?
4-pin: http://www.kazumausaonline.com/pin-cdi-wire-diagram-pi-17778.html
5-pin: http://www.kazumausaonline.com/pin-cdi-wire-diagram-pi-17776.html
anderkart
I understand you have to hold both buttons down to get it running, but do you also have to turn the key on, or doesn't that matter?
Sounds like the easiest solution might be to replace one or both of your dash button switches with toggle or rocker type switches. Maybe those 2 switches are supposed to stay down when pushed in, and they're simply defective...
Did the guy that sold you the buggy give you any clues that might help us? (like had he Installed a different engine, or replaced any of the electrical components, or cut/spliced/changed any of the wiring in an attempt to fix this problem?
Does your CDI look like this pic?
And If so, what wire is missing from its plug?
mailman2000
I will look when I get home.. but he bought never got it running so not sire if someone has rewired something
ML-TOYS
long island, new york
I dont think thats wired right or your just doing it wrong. The one button with the shocking bolt in the middle is START, the one with the line thru it is the KILL button.
anderkart
Must be wired wrong it won't do anything until you press in both buttons
I think I have a very simple solution to your problem, but first you need to answer these questions:
1 - Do you also have to turn the key switch on to make your engine run, or not?
2 - How many wires are connected to each of your 2 push button switches? (is it 2 wires to each switch?)
3 - Does your engine have an electric-starter, or does it just have a pull-start, or does it have both?
thepattonman
Charlotte NC
It looks like the starter switch is a momentary switch that is normally open and the battery switch is a push on push off with the key. With out seeing the wiring that is my best guess,I agree with an eariler post of changing the battery switch out with a toggle switch. I hope that helps.
