Paden87
I have a Briggs 900 on a doodle bug and I have a vibration when I am at low speeds but when I open it up it goes away. Not sure if needs to be tuned or what it could be. Any ideas would help
Put some kind of of cushion between the engine and the motor mount. a small piece of StyroFoam Sheet should be very inexpensive if you buy some. Use a piece of that. Should help tons.
i bet an even better working idea(its a bit out there but it would work exceptionally well at masking vibrations)even better would be to fold some shirts or thick shower towels and use them as a buffer. Would hardly feel ANY vibrations if you use enough after you nail holes for each bolt.
y'all were talking about rubber isolation pads or somthin for a engine. idk
So just to
Then why in the wide world of sports does Azuza manufacture and sell those???
So just to
