Hello,
I am kitting a build and want to make sure I am not going to run into problems with the valves/timing. Any advice is helpful. Thanks!
Engine Build:
Predator 212 (non-hemi)
Gov and oil sensor removed
.010 head gasket
5.26 chromoly push rods
Billet flywheel
Billet connecting rod (with bearing ofc)
.308 camshaft
36 LB springs
1:1 ratio rockers (not original)
Valve cover spacer
Mikuni Clone carb
Exhuast and air filter
Also, is there any cheaper flywheel than the one on GoPowerSports that is still safe up to 10k RPM?
Thanks again!
Engine Build:
.010 head gasket
Billet flywheel
.308 camshaft
36 LB springs
Valve cover spacer
Mikuni Clone carb
Thanks again!
