Engine tuning help
Jim's cart
Emerald, Qld
Hi, I am new to the group. I have a homemade go-cart I have made for my boys to ride around our yard. I have put a 49cc engine onto it but am having trouble getting it to fully rev out, no matter how I adjust mixture screw on carby. It is the 49cc "race engine", I have put a performance exhaust on it. If I go over about 3/4 throttle it bogs down. Can anyone offer any suggestions??
:welcome2: dual posts & all :stir:
Can we assume the engine is 2 stroke? If so, most small 2 stroke carbs have high & low mixture adjustments; have you tried tweaking both?
Jim's cart
Emerald, Qld
The plug was looking very brown and dry, so I have increased the oil in fuel mixture, I think a little too much as it is blowing a fair bit of smoke at the moment. The carby only has one mixture screw and I have tried just about everywhere to get it to rev.
Jim's cart
Emerald, Qld
I haven't cleaned the carby as the engine has only done about 4 hours running. I have had the fuel bowl off the carby and there wasn't anything in it.
Clone
MotorHead
Did it run better before and now your having this problem?
Sent from my HTC One S using Tapatalk 2
DS13
Annoying the Neighbors!!!
Elysburg, PA
I'm assuming its a new engine then..
If not try taking the entire carb off and clean, it never hurts to clean, and is it jetted correctly?
Jim's cart
Emerald, Qld
It is only a new engine, so i assume it is jetted correctly. I really haven't been able to get it to run yet, it would do a few laps of the house and then it seemed to be bogging down until it stopped. This was during some 40 degree days, so I thought it was something to do with the high ambient temp plus the heat developed from the engine. If I left it for half an hour it would start but again it would not last long. The days are a bit cooler now, but the engine still developes a lot of heat. It had a blue anodized head on it that the heat has discolored. I have suspicion on the fuel I was using, so I will try new fuel and a new mix of oil and try again.
Jim's cart
Emerald, Qld
The plug looks good. I made up new fuel today and it went well for about twenty minutes, then it seemed to run out of fuel and would not start. Does a fuel vapor lock seem possible? The engine gets very hot for only twenty minutes of run time.
Jim's cart
Emerald, Qld
I have not worked out how to add pics yet. I had it running this morning for five minutes, if that and idling mainly, no load at all, and the engine was very hot again.
