First off, thank u everybody for your replies. As far as the spark plug goes, it could probably use a change, it seemed to give a sufficient spark when I tested it, but it is dirty so I'll deffinately give that a shot. As far as testing the valves, I tryed the light test and didn't see anything but I did turn the head, valves up and put fluid in the "dome" and it did leak thru, don't know if that means anything. The piston is in correctly, not a silly question at all. The piston was marked kind of like the claymore mine, lol, this side faces enemy. Timing is on, good gas flow, i know the previous owner and he cleaned the carb right before i took it, but im going to take it apart and check it anyway. Vibrated when i first started it up after the ring and piston change, but turned like a top after it warmed up. It did seem to run really hot tho.
