engine trouble
el~bryce`o
here is my honda 3.5hp. it was going but it was leaking out of the carby. turns out that the float had a hole in it. so i replaced it now the engine wont start. would iit be because i put thefloat in wrong?
oscaryu1
Did you replace the float or the carburetor?
Spray some starting fluid in it, see if she fires and keeps running.
Russ2251
AZUSA:Powered by LAWN-BOY
Height of float must be set to factory spec by bending float tang that contacts needle.
