Engine Stalls when gas pedal is depressed
psu1987
I am working on a Yerf-Dog Go Kart and I can't get it running. I have thoroughly cleaned and rebuilt the Carb, replaced the fuel and fuel filter and replaced the electronic choke.
The engine will start and idle but stalls as soon as you give it gas. Being that I just put new jets in the carb an other thoughts? The rebuild kit did not contain a diaphragm should I replace that as well? It doesn't appear to be damaged.
