Engine stalls at 3/4 to full throttle
gallagher19
Fonthill, Ontario, Canada
Hello guys. I need your input here. I have just received a briggs and stratton engine which my neighbour use to race on dirt. He said it ran good when he shut it down for 4 years!!! He drained the gas when he put it away. Soooooo I changed the oil and put fresh gas in it. It started up on the first pull, but it took a while to idle. Than when it was idling it seemed to idle a little high (who knows). After about 5 minutes of letting it idle I tried to throttle it and it died. I tried this procedure quite a few times and it still would die when I went past 3/4 throttle. Does anyone have any ideas for me? Thanks again.:furious2:
DCProductions
Cockney Ragamuffin
Louisiana, USA
I would say a carburetor cleanup would do it well. Adjusting some of the carb features might help also, but only if you know what you're doing (I personally don't know what all the knobs and screws on a carburetor do).
The next place I would check/clean would be the valves. I would check valve lash and torque on all the bolts.
Then compression I guess
Brandon1023
needs an oil change
Miami, Florida, Dade County 305
Just because he drained it, doesn't mean all the gas left in the passageways of the carb escaped. The proper way to do store an engine is to drain the tank completely and then run the engine until everything in the bowl is burned up. THEN.. continue to turn the engine over enough times until it will no longer fire.
As for your problem.. once you open up the throttle, the carburetor is too restricted by build up to compensate for the larger flow of air coming through the throttle reducing the amount of fuel in the FA mix, killing the engine. This thread will show you how to clean it.
Edit: That's not my favorite way to clean it, but it will do if done correctly. I did a Google search for you and this explains the method I use on all the mowers I fix.
some other forum said:
I got a cheap pot from the dollar store, ($5) and 4 quarts of lemon juice, fill with water to cover the carb, turn on my turkey cooker on low, let it get how, but you don't have to boil it. Take it out after 1/2 hour and let it cool and see if things move, if so, then dis assemble, put the body back in, the little parts I clean normal, in fact I don't leave the body in very long, it will get eaten by the citric acid.Be careful with times in that bath, the less that do the job, the better. It does eat aluminum, no doubt about that, but it loosens all the crude too, quickly.
anderkart
Surprise Arizona USA
While I agree with the other guys advice, I'd start by asking your neighbor if your carb/engine was set up for running gasoline or Methanol. Most guys that race on dirt oval tracks run Methanol with super high compression, lots more timing advance and carbs that are jetted much richer than a gasoline carb would be. If your carb/engine was set up for methanol, your only problem might be that your using the wrong type of fuel...
gallagher19
Thanks anderkart. You were right on the money. I bought some Methanol. Started the kart up 2nd pull and wow!!! It runs awesome. Now I have to pack my track in. This kart is going to be the fastest in the group!!! Time to have some fun.:thumbsup:
