ibrahim123
- Messages
- 123
- Reaction score
- 0
Okay guys, i was trying to get my engine working and after carrying out some tests i found which wire was the one connecting to the coil. so i connected the 2 wires together and when i key start, i do not see any spark...
Hmmm could it be the coil?
We then tested the coil and we know that the coil works as well.
What does this mean? That electric power is lost when we connect the coil wire with the wire which gives power from the engine. Why does that happen? Can it be fixed?
Btw the coil has 2 wires. 1 which is for the spark and the other which connects to the engine wire which gives the coil power. The ground is not a cable its like a block of metal which screws on to the frame.
