What numbers do you need for input?
Bore?
Stroke?
Rod Length?
Head Type?
Flat Head, Wedge, or Hemi
Compression Ratio?
Valve Size?
Port Dimensions?
Carb cfm rating?
Exhaust Length and Diameter?
Camshaft Intake lobe duration and lift?
Intake lobe center line?
Exhaust lobe duration and lift?
Lobe separation Angle?
Rocker Arm Ratio?
Does EA provide the optimized spark advance numbers?
If you look near the bottom of the of the chart....
stock, stock, stock, stock, stock, stock, stock, stock,
exhaust = https://www.bmikarts.com/Exhaust-Header-Pipe-for-Super-Stock-Clone-Class_p_37.html with RLV muffler
stock, stock, stock, stock, and stock.
obviously nothing special from the starting Lifan 168F.... but that makes me think a cam and rod will be my next distraction after getting the torque converter (TC) worked out. Am I at the top of the TAV30 capability at stage 1 or 2 mods? Or stated another way, if I increase power any more do I need to go to the next TC?
