Go Cart shuts off when move throttle upMy go kart doesn't really start. If I put it on low throttle it will start but soon as I move the throttle up the go kart shuts off. Any ideas
It sounds like the carb is blocked, give the jets a clean then wipe the spark plug and give it another try, should sort it. ......( do this after screw replacement on throttle if it isn't fixed )
And as to the screw if it's on the throttle then it needs to be about 2 turns in to keep the engine running, otherwise it will cut out,
If it's on / in the carb then that's the mix screw , without it the engine will run rich, wich isn't good for the engine.
If it came from the side of the Carb then that would be the mixture screw and would need fixing , what color is your spark plug? I've got a feeling that it will be black and wet indicating that the mix is way too rich.
Fix/ replace screw , turn it all the way in till it's lightly seated then turn it 1 & 1/2 turns out and go from there, couldn't hurt cleaning the Carb and jets too just to make sure.
