I just got a Manco Scorpion that has a 6.5hp Craftsman engine.. I also bought a 3/4" Hilliard Extreme Duty clutch for it since the old one was slipping. Though when I drive about 600ft the new clutch starts to slip then becomes useless after 650ft. I have 2 other engines I can choose from. One is a 8hp Techumseh w/ a 1" shaft, the other is a Briggs 10hp 7/8" shaft but it's off a generator so it's elongated/tapered and non-slotted. If I were to machine or grind down the shaft on either one would it work out for me? Whole idea is to avoid buying a new clutch.
